Wayne_Dohnal
Jun 18, 2013Explorer
2oldman wrote:omygosh - I messed up - meant to say MSW waveform. That's the 2nd mistake I've made in this thread, should probably be kicked off. What I really think at this point is that the collection of information doesn't make a whole lot of sense, and there's a need to take good AC and DC voltage readings at both ends of each circuit when running the microwave.Wayne Dohnal wrote:If I'm reading your post carefully, and I think I am, you're saying a PSW inverter does not produce a very good sine wave. Is that correct?
The PSW waveform changes with battery voltage. As the battery voltage goes down, the power pulses widen, resembling a sine wave less and a square wave more (not that they ever resemble a sine wave very much).
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
