Hurricaner
Jun 18, 2013Explorer
I think the problem was addressed earlier. You can't run a microwave at full power on two golfcart batteries. They can deliver 75 amps with no problem but even then you might be down to 11.5 volts. At 150 amps they just won't make it and the inverter will shut down on low voltage. As said earlier you might get away with some group 31 marine dual purpose batteries but you need four golfcarts to provide 150 amps.
Sam
Sam
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
