michelb
Jun 19, 2013Explorer
Hurricaner wrote:
I think the problem was addressed earlier. You can't run a microwave at full power on two golfcart batteries. They can deliver 75 amps with no problem but even then you might be down to 11.5 volts. At 150 amps they just won't make it and the inverter will shut down on low voltage. As said earlier you might get away with some group 31 marine dual purpose batteries but you need four golfcarts to provide 150 amps.
Sam
We do it all the time ... see my earlier post. Heart Interface 1000W inverter and 2 6V (Trojan T105) batteries. I think our mw is 900W. I do believe the mw doesn't run as well as on AC (takes longer to cook) but it does work.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
