MP_soldier's avatar
MP_soldier
Why won't 2000w inverter run 900w microwave?
I bought a 2000w Nature Power pure sine inverter from camping world.
I had my local rv dealer install the inverter (and a power tongue jack) that I bought a CW.
It was $200 in parts and $500 in labor.
He put a 3 way switch in the camper (shore power/inverter/battery).
However, when I try to run the 900w microwave, after about 4 seconds I get a beep, and the microwave shuts off.
I have 2 six volt batteries fully charged. They've been plugged in for 3 days.
I'm guessing the beeping is a low voltage alarm.
Why won't this inverter power the microwave? Could it be too small gauge of wire from the inverter to micro?
I'm kicking myself for spending so much money on this thing if all it will do is power the tv.
  • MP soldier wrote:
    He put a 3 way switch in the camper (shore power/inverter/battery). Why won't this inverter power the microwave? Could it be too small gauge of wire from the inverter to micro?I have 2 six volt batteries fully charged.
    I see several issues here.
    2 batteries is a bare minimum (and often not enough) to run high-wattage devices like MW. How old are the batteries? Just because they're full charged doesn't mean they're in good enough shape to sustain a big discharge.
    It's likely the wires from the batteries to the inverter are too small or too long. It's almost unheard of that the wire to the micro is too small - if it were it wouldn't run on shore power.Wayne might be thinking you said the wire from the battery to inverter.
    Also, the switch.. depending on where that is in the circuit could be affecting performance.
    To add insult to injury, that brand of inverter is not exactly top of the line...but I don't think it's your problem.
  • Read the label or the manual for the microwave oven.
    It will tell you how much current (Amps) it draws. Multiply by 120 to determine the AC power drawn from the inverter.
    The power rating on a microwave oven is the output power from the magnetron tube and they are only about 50% efficient.
  • Could it be too small gauge of wire from the inverter to micro?
    That's the most likely reason. Measure the voltage at the inverter as the microwave shuts down, then do it again at the battery, and see how much you're losing in the wires.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
