jjrbus's avatar
jjrbus
Wi-Fi, Blue tooth antenna question.
Purchased a Atoto A6PF for my 02 Roadtrek and trying to muddle my way through the instructions.
One connector has a large yellow plug for rear camera, I got that one. Then there are 3 wires labeled Wi-Fi, Blue tooth and parking brake with little clear plastic pieces on the end.
Are the little plastic caps the antenna or do they have to be connected to something?? Cannot get picture to post?
https://i.imgur.com/w1ioUocl.jpg
[img][/img]
  • Thanks appreciated.
    The 01 Chevy van has a metal frame around the radio, seems an antenna would not work well in a metal box?
  • the plastic caps are to insulate the wires from touching any bare metal in the dash. the parking brake wire should connect to the switch on the parking brake so the driver cannot watch video when the vehicle is moving. the wifi and bluetooth wires are antennas just as they are.
    this picture on the amazon page shows the wiring it will also be in the instruction manual wiring diagram
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
