garyemunson's avatar
garyemunson
Explorer II
May 23, 2019
WiFi Boosters
What is the latest on WiFi boosters? Anyone have good or bad experiences with them? I see many new higher end coaches are coming with them. Reading the reviews on Amazon, PCMag and CNet, I see almost as many people who don't like them as think they are great. Some of these devices have to wire direct via USB to your computer, some are stand alone, some have rooftop antennas, some don't.. If one works, I'd like to permanently install it in our motorhome. So many different types out there it's beyond confusing.
  • I currently use a Ubiquiti Nanostation combined with an Air Cube router for WiFi. At Quartzsite, I was able to connect to the local Pilot close to a mile away. The Nanostation does require a bit of configuration - a useful YouTube post explains setting it up is at the Outside Our Bubble website..
    As others have said, the biggest problem with WiFi is usually the available bandwidth. I do use the Nanostation at places where there is WiFi but no cell coverage, but like others, prefer a Jetpack or Mobley using Verizon or AT&T.
  • Gary,
    WeBoost are great, but they are only for cellphone signals.
    If you are trying to do better with campground WiFi, the first thing to do is to look at the signal strength display on your device. If it is more than one bar, the booster will only serve to frustrate you. If there is signal, but no bandwidth (speed) then the system is overloaded. Most are most of the time.
    If signal strength is a problem and you are not a homesteader, then look up Alfa 036(XXX) units on Ebay. They are inexpensive and very portable.
    If you really need wire (internet), then you really should investigate cell service.
    Do I need to say BTDT???
    Matt
  • dougrainer wrote:
    AllegroD wrote:
    ReneeG wrote:
    We permanently installed the WeBoost in our FW and there's an antenna mounted to the roof. It works. As the name implies, it boosts what little signal is there. If no signal, it won't work. As opposed to a mifi - that you pay service for, you don't have to pay service on the WeBoost.
    Is there a new version out that does WiFi? WeBoost that I am aware of boosts/repeats cell signal.
    Not sure The dome is $369 and the 3 antenna one is $750. Doug
    Doug, Yes. Winegard has those out. My question was to the quoted from ReneeG. I thought WeBoost was only cell repeater.
  • We permanently installed the WeBoost in our FW and there's an antenna mounted to the roof. It works. As the name implies, it boosts what little signal is there. If no signal, it won't work. As opposed to a mifi - that you pay service for, you don't have to pay service on the WeBoost.
  • I see Winegard has 2 different systems. A "dome" type and a 3 antenna one. Are they basically the same thing?
  • Don't forget that it won't help speed up the local campground wifi, it will only help you access it more reliably.
  • The Winegard roof top Antenna WIFI system works great. It works 2 ways.
    1. Takes the local WIFI and rebroadcasts it in the area in and around your RV
    2. You can also get an "aircard" from your Cell phone provider and THAT gets the 4G and rebroadcasts it inside your RV and outside also. This is for when in transit or you are not close to a WIFI signal. Doug
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
