Almot
Dec 07, 2015Explorer III
The full picture is slowly emerging. Finally, after 4 pages :)
You are a very light user, you have an adequate inverter and more-less adequate solar (have some doubts on 120W being adequate, but in sunny climates - maybe).
Yes, you can get away without using a 2nd battery.
But I don't see any benefits in keeping 2nd one as a spare, as opposed to using it. Here is why:
- Batteries rarely die suddenly. Usually, they wear out. It takes YEARS. You'll have plenty of warning.
- Your solar will (probably) keep 2 batteries same happy as it does with one, because again, you're a light user - probably starting with 85% full in the morning, so your solar is capable of generating more amps than 2 batteries would need, because batteries are near full. When they are near full, they can only accept very low charging current. (This would need further testing, re: your weather pattern etc, but you've got the general idea).
- Your spare battery (if you keep it spare) will self-discharge slowly while you're not using it (though this won't be notable if you camp only 3-4 days at a time).
As to the inverter - I like SMK idea to mount it near DC fuse panel and converter, 'cause you'll find there DC lugs and a convenient spot to wire the AC from inverter into your AC circuit. Just make sure you have access to inverter switch, because for a very light user with very small solar the inverter should not be left On all the time, wasting precious AH.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
