pianotuna
Dec 10, 2015Nomad III
Just what a boondocker without consuming 12 volt power who wishes to heat with propane needs. It even has a thermostat. It is available at Amazon for a lower price--but the write up at Home Depot is better. I believe it is lower cost than the unvented (and hence UNSAFE) wave catalytic units.
http://www.homedepot.com/p/Ashley-Hearth-Products-8-000-BTU-LP-Gas-Direct-Vent-Heater-AGDV8L/206165166
Use and care manual:
http://www.homedepot.com/catalog/pdfImages/59/596984a9-53a6-41f3-a93d-85c9bf4945c9.pdf
NinerBikes wrote:
I see a couple of options.
Change usage pattern. Have you considered turning off the HVAC unit with fan, and replacing it with a Olympic Wave 3 Catalytic convertor, runs off of straight propane, no electrical fan running? It is an option.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
