- mike-sExplorerWow. 5 pages to answer the question "will a voltmeter work as a voltmeter?"
- MrWizardModerator
- mrmombExplorerPanel lights are called IDOT lights after all. My father often tells me that his panel says that he is fully charged, my DVM says he is at +-70%. Go figure, his WFCO charges at 13.5V. OTOH, I charge at 14.55 and rely on the .0x significant digit. I want to know if I am at 80% or 85% SOC. Depending on the plug in meter, they will show that I am at 50% to 100% SOC. Accurate data is king. ...Yes, I do monitor Amp Hours, home brew.
73,
K2LED - MEXICOWANDERERExplorerFive different meters sitting in a row...
Thirteen point three seven high, twelve eighty-five, low...
Funny? Tell that to the five meters I have lined up on my table. The worst are the five cigar lighter three-digit meters. I tripped them down by adjusting Borg Voltage, up and down then tweaking halfway to get 12.8
Muh batteries is charged (at 12.8)
Muh batteries is charged (at 13.37)
Wait! It's the same! Isn't it? I mean they all start off with "1"
I pulled an abdominal muscle laughing and had to forego breakfast. I unclipped them and shoveled back into the junk drawer. - jayw900Explorer
Trackrig wrote:
I have a Nash 26X trailer. It's a nice TT, but it has the standard stupid idiot lights that don't really tell you much. Will a little, easy to mount, cheap digital gauge like this work to tell me my battery condition?
Round Voltmeter
Rectangle Volt Meter
Other suggestions?
Bill
Either of those are a good choice. Eventually you'll learn how much your voltage sags so you'll know what the true reading is whether there's a load on the system or not. - MEXICOWANDERERExplorerSome folks don't mind buying a new battery every couple of years and then there's the specialty multiple battery owner who would shoot-on-sight anyone who told him to maintain his bank by guess and by golly.
- Harvey51ExplorerJust be aware that a voltage of 12.6 may mean the batteries are fully charged or fully discharged. Say you charge at 13.6 volts, then stop charging. The voltage will be 13.6, gradually diminishing over the next 8 Hours or so with no current being used as the fresh charge is fully absorbed.
Battery monitors start at $25 on eBay. They measure the voltage and current, integrate to get the actual charge going out and in and display the number of amp-hours of charge in the battery and % of full charge. I have one of these and really enjoy seeing the per cent of full charge at all times. It is more work to install than a voltmeter, though.
http://www.ebay.com/itm/DC-120V-100A-Battery-Monitor-State-of-Charge-Remaining-Capacity-AMP-Voltage-AH-/182147916411 - SaltiDawgExplorer
Muddydogs wrote:
Considering I'm looking for accuracy from 12.0 to 12.7 volts why worry about accuracy from 0 to 20 volts? ...
The range of the meter has everything to do with the accuracy of the measurement being made and displayed.
An Explanation of Meter Accuracy - dclark1946Explorer
RJsfishin wrote:
You don't need a 3 digit for your (and my) purpose. The only good the 3rd digit does it tell you when the 2nd digit is about to change.
And accuracy (w/ in 1/10th) is not that important, as long as it is consistent, and most all voltmeters are.
Knowing the SOC is easily learned by consistent loads. Like I know what the voltmeter reads when I get up in the morning, and I know what it reads when I go to bed at nite, having the same loads both times.
If the fridge happens to be running, that does not change the voltage enuff to change anything.
If you must check voltage at other times when heavier loads....like tv, sat DVD etc, then you must put the more loads into the voltage picture.
I know my system so well, I have no use for a "monitoring system"
I agree with this practical response. I would even add that the battery lights are very useful if you take the time to check the battery voltage with a good digital meter a couple of times for one and possibly two lights off as a rough calibration. For example, I expect that my indicator will have one light off in the morning with basic fridge and water heater loads after a night of running a Maxaire fan. If I go check at the battery test points it will read 12.4V using a Sears DMM. I run the generator every morning so there is no use to check the voltage every morning when a simple push of the monitor button tells me everything is normal. I have never seen less than one light off (except when I had a bad battery) because I charge daily and our daily loads typically do not vary that much.
I do check battery charge current both initially after starting the generator and after we are through with breakfast to see if the current has tapered off enough to shut off the generator. - red31ExplorerLights went out, not from an inaccurate voltmeter
Gotta start the gen - smoke em if ya got em
Like campfire cooking - Yes
Ewwww the outside is all black - as expected - enjoy it
Ewwwwwwewwwwwee the inside is raw - personal problems?
Better n starvin.
Anyone want a couple pounds of voltmeters? You pay postage. 5 minute warranty. - No
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
