BFL13
Mar 25, 2020Explorer II
The 7-pin will help while your fridge is on propane, but not do enough while the fridge is on 12v if it is a 3-way fridge.
If the fridge is cold already before leaving it will stay cold that day till you get there if you leave the doors closed.
You need a battery in the TT to tow it (it's the law) so the emergency breakaway will work.
With the required 12v battery and the 7-pin, now you can use the 12v mode on the 3-way fridge and it will help keep it colder than without.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
