DFord
Aug 20, 2019Explorer
GFCI outlets measure the power being used on the "hot" power lead and ensure the same amount of power it flowing in the neutral. If a tiny amount of imbalance occurs, it's meant to interrupt the flow of power and keep you safe. If there's no ground wire and you complete a circuit to something that is grounded, it will interrupt just as quickly as if there was one. Some devices don't have a ground wire because they're "double insulated" and you're not supposed to be able to touch a "hot" metal piece on them.
