- road-runnerExplorer III
jjrbus wrote:
I'll agree that it's on the short list, but not necessarily at the top. The "RV hot skin" issue gives it pretty tough competition for the #1 spot. And GFCI issues are pretty strong contenders, too.
Running a RV AC with a small generator has the most misinformation of any RV topic on the net. - austinjennaExplorerGood info, but I already have the EU2000 so I dont really see myself upgrading to the EU2200 and also considering we dont boondock much it might be an expensive lesson to install the easy start only to find out it wont run the AC. I guess it all depends on a lot of factors wether it would run the ac smoothly or not
- jjrbusExplorer
Itinerant1 wrote:
Kind of weird that some can run a 15k off of a eu2000i and some not.
Running a RV AC with a small generator has the most misinformation of any RV topic on the net. The confused me but good, cost me some grief and money.
One person insisting he ran his roof air all the time with a 2000 with no issues. Turns out he had a no longer available Coleman mini that was 8000 btu!
Know how some people get 13 mpg out of a vehicle that no one else can get 10 mpg out of, I suspect it is the same with AC! - buckyExplorer IIIs the converter off with the fridge and water heater on propane? If so you have a better maybe.
2000 watts is almost 17 amps.
There are 13.5K ac units everywhere, do a search. - ktmrfsExplorer III
not really weird. a lot depends on the AC, temperature, and density altitude. AC inrush and running current can vary enough to overload a honda 2000 or be just fine. And then there is the outside temperature which affects AC running current and density altitude which takes into account temperature and RH and affects the engine output and hence generator max current output for the honda 2000. High temp and high RH at sea level can have the same effect as running at a lower temp and lower RH at 3,000 ft or higher.
And thus a 2000VA generator bounces between "almost adequate" and "barely adequate" depending on the above variables. - Itinerant1ExplorerI haven't seen or at least remember in this thread if at high elevation did you change the jet?
Kind of weird that some can run a 15k off of a eu2000i and some not. - ktmrfsExplorer III
ReneeG wrote:
jjrbus wrote:
austinjenna wrote:
install a microair easy start and you'll be fine on the smaller generator
Thats what I am thinking of doing to run my 15k from my Eu2000
Hmmm, a Coleman 15k unit shows 1520 watt draw standard and 2025 watts desert. These are ideal condition #'s. I would think borderline for the 2000?
That's why some here recommend the 2200.
altitude is the other issue with a 2000. the 2200 has a little extra omph but a LOT extra displacement. IIRC 125cc vs 100 or less on the 2000. My experience and my brothers is that the 2000 is fine with our 13.5KBTU AC (coleman and dometic) up to about 3000 ft. above that and it will eventually overload. Meanwhile the 2200 will run at less than full throttle all day long at 7,000 ft with about 300VA to spare. And that is without rejetting for altitude. So, honda did two things right. (1) a little extra output (10%) and (2) A noticeably bigger engine (25%). and I suspect (2) is the big saviour at high altitude.
Our 2000 went to our son and I and my brother picked up 2200's. I alsos have a 2000 companion, but that has been unecessary since we got the 2200 and the easy start. - ReneeGExplorer
ktmrfs wrote:
philh wrote:
Seon wrote:
Aren't the easy start, soft start and hard start all functions the same on the start-up?
Microair easystart electronically spins up the compressor at a slower rate. I believe the hard start is a big capacitor that may or may not work.
exactly. night and day difference. with my coleman and the microair easy start PEAK inrush current to start the coleman is less than 20A for less than 2 seconds. honda 2000 in eco mode will start the AC easily with a nice smooth ramp up in generator rpm. For reference w/o the easy start I measured >50A inrush current needed to start the coleman even with a hard start cap installed. Very close to the spec'd LRA for the coleman.
The easy start has a "learn" mode where you start the AC unit something like 6 times from a "stiff" source, e.g. your house shore power. First start inrush will be near LRA, each start lowers the peak current till about the 5th or so start when it levels out at a final value, around 20A. Once you are done with the "learn" mode, your all set to start using a generator to start the AC from a generator or shore power.
Good to know about the "learn" mode. Thanks. - ReneeGExplorer
That's why some here recommend the 2200. - jjrbusExplorer
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
