Gdetrailer
Jan 08, 2022Explorer III
philh wrote:Gdetrailer wrote:
WFCO converters use a voltage and current sense along with timers, if too much current is being drawn during storage and the voltage is low enough over a specified time limit it will never go into storage mode (13.2V)
And yet when I replaced the POS WFCO, my problems went away.
They are well known for never going into bulk charge and not cycling storage. They are cheap junk POS.
:R
And yet, I did mention different converters handle some conditions better than others and some not as good.
I am merely telling you what the problem is and how you can adjust or correct the issue.
You could have saved yourself a lot of expense just by increasing the wire size (which is what others with same WFCO converters have reported on this forum). New wire is far, far cheaper than replacing a converter.
While I have a PD I would not be afraid of WFCO if I had one, just takes a WILLINGNESS to learn what the reasons are as to why it does or does not do and how to correct. You sir, most definitely are unwilling to learn :h
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
