- The WFCO is perfectly fine to float a lead-acid battery in the cold of winter. If still concerned check the battery voltage after a week of no use to see you are in the 13.2 to 13.6 range.
- 2oldmanExplorer IIBring batteries in and keep them warm. They like that.
- ivbinconnedExplorer IIDon’t know how well a solar would work here in the frozen short sun lite days of the north.
- bgumExplorerGet a 10 or 15 watt 12v solar maintainer and hook to battery. Disconnect the negative wire and turn off your converter.. Your battery will thank you
- LwiddisNomadA thirty watt solar panel with a decent controller will do the job much better. Still need to check battery water level every month however.
- theoldwizard1Explorer III would not.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
