pianotuna
Jan 25, 2014Nomad III
Hi,
My 9100 PD9140A was sitting at 13.2 volts at supper time. I used the inverter to power a hot plate for ten minutes--about an 85 amp draw. After turning the hot plate off the voltage returned to 13.1 volts. The pd did not go to bulk mode.
The battery bank is most likely at the ambient temperature which happens to be 0 C (32 f).
It is wizard equipped.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
