RJsfishin
Jan 26, 2014Explorer
pianotuna wrote:
Hi,
My 9100 PD9140A was sitting at 13.2 volts at supper time. I used the inverter to power a hot plate for ten minutes--about an 85 amp draw. After turning the hot plate off the voltage returned to 13.1 volts. The pd did not go to bulk mode.
The battery bank is most likely at the ambient temperature which happens to be 0 C (32 f).
It is wizard equipped.
This don't seem right. You were removing much more from the battery than what the converter could replace, therefore leaving the battery in a partially depleted state. Why would the converter return to float mode on a partially depleted battery ?
I am not saying that this is not normal for a PD converter, because I have no idea what mine does under those conditions.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
