SoundGuy
Jun 14, 2018Explorer
Mar-d-mar wrote:
In hot weather, on propane or battery power, the frig won't keep up.Will Solar panels be enough to do it?.
2oldman wrote:
So, your fridge works ok on 120vac then. You'd need an inverter to supply that, plus about 25amps of solar feeding the batts.
And how is solar going to help when the sun isn't shining full tilt? :@ The correct solution is to figure out why the fridge isn't operating on gas as it should. ;)
