DrewE
Jun 14, 2018Explorer III
The OP's fridge is a three way fridge.
Gas and 120V should have similar performance. 12V is usually less cooling capability. I would suggest ignoring the 12V setting and forcing it to use gas when underway, particularly on hot days.
If performance on gas is not basically the same as on 120V power, then there's something wrong with the burner assembly or its adjustment or cleaning. If it cools well on 120V power then the basic cooling unit is obviously okay and replacing the whole fridge to get the gas burner working properly is an expensive and wasteful proposition.
It takes a fair bit of solar power to keep up with an absorption fridge running on electric power, possibly more than you could reasonably fit on the roof of a class B.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
