Mar-d-marExplorerJun 14, 2018Will Solar save my frig temp?Class B Pleasure Way. In hot weather, on propane or battery power, the frig won't keep up. It does fine plugged in at a campground but I'm usually in a parking lot during the day. I've been leaving it...Show More
jplante4Explorer IIJun 16, 2018Replace the burner. Be prepared to replace the propane supply tube as well because it will probably break when you try to loosen the fittings.Tube
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
