bid_time
Jun 16, 2018Navigator
SidecarFlip wrote:My 3 way frig has a switch with 3 choices, gas, 110v, 12v. If you choose 110v and there is no 110v source the frig flat out doesn't operate. Same with the other 2 switch positions.nickthehunter wrote:Mar-d-mar wrote:If your frig has 3 settings, one is for 120V AC, one is for 12V DC, and one is for Propane. You should run it on propane then when not on 120V. This setting will be less drain on your battery.
... but the frig has 3 settings. I use AC for when I am plugged in, DC for batteries and gas-gas. If I have solar panels, can I use the AC connection instead of DC, or is there a way to plug the AC into the inverter for panels and get more power?
If the control board is working correctly, the fridge will always default to propane (if it's available), if not 110 volt and if neither is available, then 12 volts which is the least efficient energy source.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
