Tom_M1
Jun 16, 2018Explorer
jplante4 wrote:This jogged the brain a bit. A fellow camper was having issues with his fridge not cooling. When he disconnected the propane line, oil ran out. After cleaning out the oil the fridge worked fine. Something to check.
Replace the burner. Be prepared to replace the propane supply tube as well because it will probably break when you try to loosen the fittings.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
