raztec's avatar
raztec
Explorer II
Jun 21, 2015
Will this solar system suffice?
I've got a Northstar Laredo SC hard side truck camper which I'd like to put solar panels on and was wondering if this system will suffice.
Thanks for your input.
1. I currently have one 12v Interstate regular deep cycle battery. I'm ok with just keeping that. My budget is somewhat limited at the moment, but I'd like to have the option of adding a second battery later or upgrading to an AGM if you guys think that's necessary.
2. I'd like to be able to get off the grid for at least 10 days at a time, mostly in warmer climates with sunshine. The only appliances I would use are the furnace, lights, stereo and inverter to charge my camera or computer or cell phone. I won't be using a TV or A/C or microwave or much else. The fridge will of course run on propane.
3. I'm thinking 150-300W is the most I'll need. Perhaps:
a) A 160W panel from amsolar? Amsolar
b) Alternatively, the 150W panel from wegosolar. wegosolar
Or, I could have two installed if you think that's best in the long run
4. For charger and inverter I'm considering the Morningstar. Seems like they will be able to handle more batteries or panels should I choose to add them later:
a) Morningstar PS-30M charger: http://www.morningstarcorp.com/products/prostar/
b) Morningstar Inverter SI-300-115V-UL http://www.morningstarcorp.com/products/suresine/
5. As for wires, the companies and installers that I'm talking to say 10g should be enough, but everything I read says I should go with 6g at least. What do you guys think?
Thanks for any input you guys can provide before I go ahead and bite the bullet on this setup.
Cheers
  • PT, don't forget about shipping costs from u.s. to canada... likely another 60-80% added to cost. Those used 12v panels are $0.79/watt plus shipping... so say $1.25/watt, minimum.
    Local is the way to go... i bought 140w/12v panels locally for $145 can, so about $125 u.s.... $0.89/watt u.s..
    A 250w/24v can be had for $239 can., so about $195 u.s.... $0.78/watt u.s..
  • Measure first where the panel(s) will go and not have shadow issues.
    I would try to find a local panel supplier... otherwise good to go.
  • Hi,
    Much better to buy from solarblvd for panels.
    I would put on as much solar as there is unshaded room on the roof.
    The inverter choice is top drawer but a Go power or Samlex unit may be 50% of that price with similar specifications.
    Consider these used panels
    If planning on a pwm controller wire size should be based on the maximum amps that are going to be used. Going MPPT, wire size is more important.
  • I would only add that the TracerBN series may be something to consider, as well. At a little over 2x the cost of the eco-worthy, (shipping / dhl fees in) you'll have more user adjustability, as well as a higher Voc rating to work with, if considering adding more panels in the future.
    3215bn c/w remote monitor
  • Before the depression, I did a lot of boat work. Solar is a favorite among sailors. As soon as an owner asked me about it, I would sit them down with my laptop running a spreadsheet and my DC ammeter.
    One page was power demand and the next was money. Both of these have to be based on real data and only a few assumptions can be included before there are problems. Sometimes I got a job and sometimes I only made another friend. But, I never quoted a job without that analysis. When we would get done, I would offer them the completed analysis for the price of the thumb drive I would put it on.
    Moral: You have to do the WHOLE and REAL analysis to know if it is worthwhile. There is no telling without that analysis. Some place the usable sun just does not work.
    Matt
    Cheers
    Roof real estate is the main thing, but our TC has a big space up front that allows for a single 24v panel. This is a way better deal than buying 12v panels locally.
    The wegosolar 150w panel is very very expensive (recently gone up due to the new tariff) but her 24v panels are reasonable when you can pick them up no shipping cost.
    You can do vastly better with , eg, the wegosolar 260w panel (made by Canadian Solar AFAIK) and the Eco-Worthy 20a MPPT controller to run it (available from Eco-W website for about $102 US last time I looked.)
    That is what we have for our TC (we swap the solar out of the 5er to use in the TC since it is all portable the way we have it) Got the single 255w panel run by the Eco-W and it provides bags of solar for the least money unless you buy in the States with no shipping when you are down there.
    We carry two big T-1275s in the truck camper and last time out I also put two 6s in the truck bed forward of the back wheel and ran wires up from them hanging over the bed rail before sliding the camper in. I was then able to link the two 6s around outside and in to the two big 12s as one battery bank of over 500AH :) I could have put two more batteries in the other side for a total of six batteries if I needed to.
    This all ran a 2000w inverter on whole house for the 120v 3.2 fridge, Microwave, toaster, kettle, TV, etc with the solar keeping up even with that 120v fridge when off grid for 5 days of "mixed sun and cloud" and the batteries were still about 75% full at the end.
    So IMO for the same budget you are looking at for getting 150w you can have 260w and not have to expand later when you discover solar will let you do whatever you like off grid! :)
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
