raztec's avatar
raztec
Explorer II
Jun 21, 2015
Will this solar system suffice?
I've got a Northstar Laredo SC hard side truck camper which I'd like to put solar panels on and was wondering if this system will suffice.
Thanks for your input.
1. I currently have one 12v Interstate regular deep cycle battery. I'm ok with just keeping that. My budget is somewhat limited at the moment, but I'd like to have the option of adding a second battery later or upgrading to an AGM if you guys think that's necessary.
2. I'd like to be able to get off the grid for at least 10 days at a time, mostly in warmer climates with sunshine. The only appliances I would use are the furnace, lights, stereo and inverter to charge my camera or computer or cell phone. I won't be using a TV or A/C or microwave or much else. The fridge will of course run on propane.
3. I'm thinking 150-300W is the most I'll need. Perhaps:
a) A 160W panel from amsolar? Amsolar
b) Alternatively, the 150W panel from wegosolar. wegosolar
Or, I could have two installed if you think that's best in the long run
4. For charger and inverter I'm considering the Morningstar. Seems like they will be able to handle more batteries or panels should I choose to add them later:
a) Morningstar PS-30M charger: http://www.morningstarcorp.com/products/prostar/
b) Morningstar Inverter SI-300-115V-UL http://www.morningstarcorp.com/products/suresine/
5. As for wires, the companies and installers that I'm talking to say 10g should be enough, but everything I read says I should go with 6g at least. What do you guys think?
Thanks for any input you guys can provide before I go ahead and bite the bullet on this setup.
Cheers
Having RV issues? Connect with others who have been in your shoes.24,289 PostsLatest Activity: Jul 28, 2025
