RoyB
Oct 11, 2014Explorer III
Don't know anything about your model listed but as a whole wind generators all need to have a sustained wind of 5 MPH to meet their minimum output. This is really hard to find across the country except at a few certain place like on a sea shore or next to the mountains that have up drafts.
Some ares like the ranges up from TEXAS thru OKLA and north usually have a sustained wind blowing. Areas just East of the Great Lakes also have sustained wind coming off the the Great Lakes.
The Rest of the areas only seem to have sustained wind during weather changes events.
I have looked into using a TURBINE TYPE wind detector with direct drive feeding a generators much like what are showing here.
Best results would be with the round turbine sitting on top of a motorhome for instance going down the road at 50-60MPH... The main axle bearing should be one of those high dollar ZERO DRAG MAGNETIC type bearings... The round turbine would look very much like an attic exhaust turbine...
Turbine or blade type will have to be a large footprint to produce any large KW outputs...
Most of small blade type generator are very very noisy to live with let alone what they might do with bird life...
IMO Solar Power backed up by Generator gives you much more
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
