joelc
Feb 01, 2020Explorer III
Window Leak - NOT condensation
I have a 5er with the type of window that opens from the bottom and overlaps the RV slightly. The glass all around overlaps the RV skin. You can see the rubber gasket from if you look on the edge of the glass. The RV was built in 2012 so it is the style seen on most RV today. There is no frame on the outside, just visible is the glass. My problem is a a small leak was spotted dripping from the upper frame inside. Upon going outside I noticed that there is a slight gap in the gasket to window. (The inside screws are tight) I think the gasket is starting to dry out. I do not want to remove the window and put in a new gasket as I might have additional problems Do you all think a bead of clear Lexel would solve the problem if I put it around the top section between the glass and top of gasket?
