's avatar
Anonymous
Not applicable
Jan 29, 2025
Windshield continuously pops out.
I bought a used 2000 Fleetwood Bounder 39Z. the previous owner and friend of mine noticed the gasket had come loose on the passenger side top corner. So he had a glass guy reset the glass, so it wasn't leaking. I had it out driving it around and having some minor work done and it was leaking air again. so, I took it to a guy who got it pushed back into place again. it has now come out for a third time and I'm hearing from some other glass companies this is a common issue, but no one seems to know how to fix it or what needs corrected so it doesn't continue to happen.
Has anyone had this issue and know of a solution?
1 Reply
  • The MH is now 25 years old. The window frame may a twisted out from square. The frame may need grinding in the aria placing pressure on the windshield when installed.
    Or maybe the windshield could be ground in the corner causing it to pop out.
    Good luck with the repair.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
