Want to add a Batwing? to our Winegard antenna. When in the down position it is against the AC shroud so the added wing would not fit. Want to change the down position. Do I change the down position f...
The dial on the ceiling is keyed to the down position You flip sides on the roof All you have to do is remember the front of the antenna now points out from the RV not in towards the RV , so the disk pointer is facing the back of the antenna not the front where you want to point the antenna, put a mark on the dial for the new front spot pointing After a few outings to will have it down pat You still line up the dial marks inside just the same as always to store it away
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
