MrWizard
Feb 18, 2017Moderator
There is an 'O' Ring on the shaft
You have to disassemble from the inside to access it, lube with silicone grease or replace as needed
As stated clean and seal were the cable comes thru
Check for loose screws on the mounting plate and condition of the putty sealant
