klutchdust's avatar
klutchdust
Explorer II
Mar 03, 2019
Winegard DM elevation sensor . Loss of sat. signal REPAIRED
When I depress the button on the unit I get an error code. I went on the roof and checked and cleaned a connection with electronic cleaner, removed both connectors going to the circuit board as was suggested.
It is hard wired and has not had a 9 volt battery mounted to the panel.
expensive little sucker.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
