- Chris_BryantExplorer III might try a 9 volt battery, in case there is some interference on the 12 v line
- klutchdustExplorer IIGood point. It still reads error code, any suggestions.
- Bill_SatelliteExplorer II
klutchdust wrote:
When I depress the button on the unit I get an error code. I went on the roof and checked and cleaned a connection with electronic cleaner, removed both connectors going to the circuit board as was suggested.
It is hard wired and has not had a 9 volt battery mounted to the panel.
expensive little sucker.
Did you have a comment or question or did you fix it or what?
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
