klutchdust's avatar
klutchdust
Explorer II
Mar 03, 2019
Winegard DM elevation sensor . Loss of sat. signal REPAIRED
When I depress the button on the unit I get an error code. I went on the roof and checked and cleaned a connection with electronic cleaner, removed both connectors going to the circuit board as was suggested.
It is hard wired and has not had a 9 volt battery mounted to the panel.
expensive little sucker.
  • I might try a 9 volt battery, in case there is some interference on the 12 v line
    Did you have a comment or question or did you fix it or what?
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 06, 2025
