enblethen
Feb 01, 2015Nomad
Connect a power outlet before the TV power supply. You can get them at any auto parts store.
Should add to check to see what size wire is feeding the power supply.
You should also check what you want to plug into the inverter. DVD and TV should be far less than 4000 watts. You maybe able to get by with a 150 watt.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
