dougrainer
Feb 01, 2015Nomad
It is not just the rated power supply of the Winegard, it is the SIZE and length of the 12 volt wire supplying the Winegard. But, NO, there is no larger rated Winegard Power supply. What you do is, if you will connect to the existing wire supply regardless of its size. install a 2nd higher rated 12 volt wall plug next to the Winegard power supply. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
