cbshoestring
May 17, 2016Explorer II
doughere wrote:
There is one Wingman, compatible with all Winegard Sensar batwing antennas. Depending on the antenna, you will use 3 or 4 of the attaching plugs.
Had to cut off one of the elements due to interference; booster helped some.
Doug
This is what I would assume, since one video I saw mentioned four plugs on older antenna heads (he was installing on a 3 pin/plugs head). Just did not want to risk a "return" process if someone had the facts. Atleast you acknowledge the 3 or 4 plugs, unlike others who insist I don't know how to count (on my own antenna), or lack the skills to do the research.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
