BFL13
Nov 20, 2015Explorer II
Usually the leak is when the rubber "boot" over the hole the coax goes down (up on the roof by the antenna base) comes loose and rides up the coax, leaving the hole open.
You use some goop and put the boot back over the hole until it comes loose again. :)
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
