Horizon170
Jan 23, 2017Explorer
Wadcutter wrote:SoundGuy wrote:
Still not sure what any of this has to do though with that "??????Commander" you mentioned in your first post ... have no idea what that is. :h
I wonder if he has an AntennaTek Signal Commander antenna. That's what's on my Big Country. From the ground they look like a Winegard. They have "Commander" stamped on the housing. It works as well as the Winegards I had on other 5ers.
The Wingman doesn't just snap on the Signal Commander like it does for the Winegard. It's not difficult to put a Wingman on a Signal Commander. Just need a couple of holes drilled in the correct place and I used a couple of rubber spacers so the Wingman sits level.
That is what I have and it is toast-------at least the wiring is.
I will remove all of it to include the lift/raise mechanism and install the WG IV in its entirety. I will replace the Coax as well as I don't have continuity with the present coax. I think moisture got to the connectors.
Sorry I wasn't able to answer your earlier question better.
Marvin
