dougrainer
Aug 04, 2016Nomad
If you have a wall tstat, ALL RVP AC units have a freeze sensor that will prevent icing in any condition. So, either the freeze sensor is NOT installed in the evaporator or it is defective. If LD replaced the unit because of this, the Tech was an idiot. I doubt RVP paid for the replacement. You MUST get Authorization from RVP before replacing an upper unit and they would have advised to check the freeze sensor system, as this system does NOT come with a new upper unit. Part Changers rarely fix problems.Doug
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
