Thunder_Mountai
Feb 29, 2016Explorer II
Winnebago added transit latches on Whirlpool frig failed
Winnebago added a latch to the top of each door of the residential frig in our 40R to secure the doors. The latches are the typical cabinet latch with the hook on one side and flap catch on the other. It is a good idea in theory but poorly executed.
The problem is that the catch has pulled loose from the top of the frig. The case of the frig is very thin metal so the sheet metal screws have to bite into. Thread locker didn't work.
I called Winnebago support and they said take it to the dealer. Not on your life. I'm sure they're solution would be a bigger diameter screw which would pull loose too.
I'm really stumped on the solution. I can't access the under side of the frig case to use screw and nut. The only solution I can come up with is to use some type of adhesive to bond the plastic latch to the top of the metal case and use a larger diameter sheet metal screw. If this isn't possible, anybody got a good solution for door latches that will hold in transit.
Suggestions? I can always fall back on the bungee cord.
