Bill_Satellite
Dec 09, 2018Explorer II
Does your RV not have any fresh water holding tanks? If there are grey and black tanks you should also have a fresh water tank. You can leave the grey open as long as you have a sewer hook up as you won't want to be draining on the ground in the park. Also, if you do have hookups, be sure to empty the drain hose as well as it will freeze a bit over and over and then clog.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
