dougrainer
Oct 23, 2018Nomad
What you posted does not make much sense. Clarify what you mean.
1. on 120, the temp of the water is about 160 degrees. There should be NO heat coming out the burner flue. There will be heat at the Pop Off valve
2. WHY disable the gas Valve????????????? Just turn the Water Heater LP switch OFF
3. What is the problem with any heat generated by the burner flue pipe? Doug
