dougrainer
Oct 24, 2018Nomad
As I stated, you CANNOT disrupt the LP gas Valve wiring. Verified by Atwood. If you disconnect the Gas valve the 120 side will NOT function. The circuit board does read the gas Valve coil on 120 and if there is no reading, will lock out the operation of the 120. Doug
