First time winter camping. I have a heated water line but not sure if I hook up to fresh water inlet or on board tank . I have 2013 coachman class a. It has a heated under belly.
I concur. Fill the tank and drain the hose. If you should leave water in the hose, you may end up with an X feet long iron bar to deal with. The even worse case is that you do manage to bend it and it breaks.
Matt We used to do a lot of cold weather camping.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
