First time winter camping. I have a heated water line but not sure if I hook up to fresh water inlet or on board tank . I have 2013 coachman class a. It has a heated under belly.
If you have a commercial heated water hose (assuming that's what you mean by water line) you likely don't need to disconnect the water line assuming you keep it plugged in but that will depend upon how the campground water system is setup. It's certainly not necessary to keep the hose hooked up but that's what that hose is designed for. Check with the campground and verify your plan and their setup so no one has issues.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
