I'm leaving for Florida in a few days and my fiver is still winterized (wtr heater empty & bypassed and RV antifreeze installed). I'll be travelling for two days with low temps of 20-30F. When should ...
If you're leaving from Arkansas you should be able to reach safe temperatures in about a half days travel. Might consider changing your route unless there is a reason NOT to. If you choose to stay in cold weather longer then leave the RV winterized until you do reach warmer weather then pull into most any campground or RV park that has sewer hook ups and spent a half hour or so doing the job there.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
