DrewE
Oct 12, 2017Explorer III
Flapper wrote:
BTW - most bursting of pipes is due to air trapped between areas freezing water (or water and closed valves), not the ice itself. As the ice expands, the trapped air rises in pressure, to the point where the pipe or fittings give way.
I'm no expert, but wouldn't it be more likely to be trapped liquid water than trapped air? The change in volume required to compress air to a pressure that would burst the pipe would have to be quite large; it would have to be squeezed into something like an eighth of the volume to increase the pressure from atmospheric pressure (ca. 14 psi) to 100 psi over atmospheric pressure and so apply a 100 psi force to the plumbing. (This is a pretty straightforward application of the ideal gas law.)
Liquid water, on the other hand, is essentially incompressible.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
