tenbear
Oct 12, 2017Explorer
We are in Northern Vermont and I just winterized this morning. I elected to use RV antifreeze but in the past I have used both methods, blowing the water out and using RV antifreeze. Both methods worked well.
If you unsure which method you want to use, do both. Blow out the lines, then fill the lines with antifreeze.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
