John_Joey
Oct 12, 2017Explorer
Most of those that don't know about extreme cold also don't know about concrete foundations breaking either. Like I say, you only know what you know.
1. Blow out lines, drain HWH.
2. Set bypass on HWH and run RV antifreeze via pump.
3. Blow out antifreeze, catch and use again or use in the traps.
Depending on your rig will net you different results. I've had rigs that during the blowing out the antifreeze cycle, clear water would run for a cup or two first. Whole process is about 15 minutes and $5.
It's all about risks vs rewards.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
