FLY_4_FUN
Oct 12, 2017Explorer
I dont understand why you would want to blow out the lines with air then pull antifreeze into the system? When you correctly pump antifreeze into the rig and open one tap at a time until pink comes out you have ensured water is GONE from the lines! Finish up by ensuring city water valve is depressed once pump is off and your good to go. Seems like an extra step vs just using antifreeze.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
