DrewE
Nov 12, 2017Explorer III
I use a $100 ten gallon tank compressor from Tractor Supply, though virtually identical models are available from everywhere. I set the regulator to around 40 psi. When a tap is open, it almost certainly isn't maintaining the 40 psi because it runs more or less continually.
Did you try going around to all the taps etc. (including toilet, low point drains, etc.) in succession a couple times? Maybe the water you hear gurgling will be expelled from some other place. Hearing it gurgle does suggest that there's sufficient water in a low spot to block the line fully, which is more than I'd care to have freeze there.
It can take a little while to get every last minute droplet out of the showerheads on my motorhome.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
