lordnorth
Nov 13, 2017Explorer
Thanks for the replies to my questions... except that maybe you guys missed the part where I specifically said that I DIDN'T want to use anti-freeze because I want to use it on weekends and don't want to add and remove anti-freeze from the system 8 times in two months.
I know anti-freeze works. I have used it for the past three years. I'm looking for an alternative.
I might have to give the compressor a try. Everyone talks about pressure, bot not necessarily volume. How much volume do I need to push through to make it work...?
I have a little 12 volt tire inflator that goes to 120psi... but I'm sure doesn't have the volume to make a difference.
-Chris
-Chris
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
